Lighting Transformer Fault | on ElectriciansForums
Discuss Lighting Transformer Fault in the Australia area at ElectriciansForums.net
M
mcummins7
Do lighting transformers (20-80W) when faulty give out live voltage on both line and neutral loads?
Normally on the secondary of the transformer they go open circuit when faulty there fore they will give they give 0 volts , if you are testing between the L and N terminals then you will get volts as this is the primery of the transformer
Ensure individual power points are not overloaded. For more than 2 cord plugs use a suitable adaptor board instead of a double adapter. Keep all electrical connections away from areas that could become wet due to watering or extreme weather conditions.
In which there isn't a permanently installed safety switch, use a portable type from the power point. If all else fails report lighting transformer defect to the manufacturer. Good luck with the warranty.
Reply to Lighting Transformer Fault in the Australia area at ElectriciansForums.net
Interesting. Sounds unusual since it seems it was very lightly loaded. Not much you can do I suppose other than buy a replacement unit. Unless...
One of those backlight Chinese testers may have helped that’s if the tester didn’t catch fire or electrocute you. LED TV Backlight Tester 12W LED...
2 3 4 5
4K
