Lighting tripping rcd | Page 3 | on ElectriciansForums
Discuss Lighting tripping rcd in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Having just read this thread - what testing would have put the OP on the right track more quickly?
Would continuity test at each lighting point between L and N, and then Insulation resistance tests between lighting N and all the other circuit neutrals have worked in showing the problem?
[Just trying to be prepared for when it happens to me :D]
isolate power ,turn off mcbs
disconnect circuit causing problem(L and N)
switch on borrowed load
check between circuit causing problem(L :edit) to other neutrals(one by one)
until you get your reading
that should trace it-might be easier ways
check between circuit causing problem(L or N) to other neutrals(one by one)
You wouldn't do continuity tests first? On a completely unknown circuit wouldn't that be the thing that would tell you about the state of all the conductors and eventually that there was a problem with the neutral :confused:
and not sure what you mean by "switch on borrowed load" (and how do you know which to turn on)
Am i right in thinking that the problem was a live from a lighting circuit to a light fitting and then returning to the CU via another circuit (socket ring?)
Eco-tech - did this fault just show after a CU change or...
had someone been doing a bit of DIY bodging?
just intrigued as to what had happened previously - cheers
take this problem here where you know which pendant is borrowing -we said more or less the same thing
-first disconnect circuit
-bulb out, check between the pendant neutral(with a wander lead) and other circuit neutrals
- bulb in place and switched on you can check between the circuit phase at the board and other circuit neutrals
thats what i'm thinking,never had this problem
Cheers - Reckon i'll just hope my probs are more straight forward - Last time out it took me ages to discover that owner had put a curtain rail screw thru a cable supplying his outside lights which he hadn't used for 6 months. Should have been an easy one but not helped by faults on the garden lights as well - mistakenly thought that the problem was just outside:eek:
Reply to Lighting tripping rcd in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Exactly. I was going to ask on the earthing once he clears this boiler fault (suspect on internal component). OP mentions oil boiler but makes no...
Build up of Earth leakage from multiple machines and the planner just tipped it over the edge?
