Lighting wiring | on ElectriciansForums
Guest viewing is limited
Discuss Lighting wiring in the UK Electrical Forum area at ElectriciansForums.net
Looks like the downstairs lighting is all wired from a central junction box hidden in floorboards, was this standard in the 70s? Cheers
  • [ElectriciansForums.net] Lighting wiring
My 1970s semi is the same for the upstairs lighting, but wired in single&earth rather than twin&earth. All from one central junction box. Daz
Re joint box. Usually on the landing. Later though due to fitted carpets I used to put them just inside a bedroom door so as bit more accessible at a later date. Hate joint boxes now....all 3 plate wiring now....but now hate light fittings designed for one cable only!
Agh! Seconded, cos obviously no one ever wants 2 lights (or more) so why bother making room for them!
And god forbid having to fit one in place of an old pendant with more connections than Clapham Junction!
Reply to Lighting wiring in the UK Electrical Forum area at ElectriciansForums.net
Or just put Dusk till dawn lamps in them.
can you add a bit more information for those of us who are as thick as 2 short planks please as I for one do not understand the question
