Lighting with contactors and Emergency lighting wiring | Page 2 | on ElectriciansForums
Discuss Lighting with contactors and Emergency lighting wiring in the Australia area at ElectriciansForums.net
G
gerard
Hi,
As part of my college project I have to design the electrical system for a supermarket.
The florescent lights are switched using contactors. These contactors will be switched by a bank of switches at the entrance to the premises and the contactors will switch on the lights when switched. How do I go about wiring this? Also, there are emergency fittings that will require an unswitched live to feed the battery.
Can anyone recommend a way of going about this - in the simplist way possible!!!
Cheers.
Hi Tony,
I am doing an electrical course at the moment and just seen your post re contactors and lighting for Gerard. Just a couple of really silly questions. 1. which is your neutral in the diagram? 2. It is supposed to feed the coil as a control wire along with a switched live? 3. Are your switches in the diagram intended as key switches for emergencies or for the flourescent lights. Can't think of any more silly questions. I understand the coil operation through electromagnetism and all that but i have trouble following very straightforward diagrams.
Many thanks,
Jwatt
Neutral is the bottom conductor with links fitted
The switches can be any kind of switch you like, it acts as a control for the contactor
Reply to Lighting with contactors and Emergency lighting wiring in the Australia area at ElectriciansForums.net
Anywhere where the normal lights are dimmed or dimmable the emergency lighting should be of the maintained type. So maintained emergency lighting...
davesparks
Or a combined fitting in each row.
nicebutdim
N
