T
timo
Whats the new part L changes in regards to energy eff lighting in new and referbs now. how many LED or Compacts to standards should be fitted.
Discuss Lights etc after new part L changes in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Correct me if I'm wrong but the 25% have to be fittings that can't accept incandescents, so GU10, bayonet and screw fit style fittings don't count...which leaves only flourescents and ELV lighting?
I'm rewiring my flat at the moment and its a pain to have to have 2 out of my 5 rooms using flourescents.
Then if your rewiring now you can use normal BC and ES lights see article attached
H:\Building part A to p\Part A-P Approved Documents\Part L\BSRIA article on lighting system efficiencies for Part L 2010.mht
This is what is now good for us in the October changes the normal BC and ES lamp holders will now be acceptable
Reply to Lights etc after new part L changes in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
