Hi all,
I’m having bit of a problem diagnosing a fault it’s already in my top 5 of hardest faults to find.
I’ll try to simplify lights on one circuit and also lamps plugged into sockets on the ring main sometimes flicker indicating it’s not just lighting circuit. My first hunch is loose connection in consumer unit rcd. Split load dual rcd however sockets and lights are on separate rcds. Next hunch the main switch is at fault however connections are tight and secure. It’s a terraced house with overhead supply apparently neighbours do not have same issue so can rule out loose connection on supply side HELP!!!
