Lights keep tripping... | Page 2 | on ElectriciansForums
Discuss Lights keep tripping... in the UK Electrical Forum area at ElectriciansForums.net
N
Newbie90
Hi all
Has anyone got any ideas why a lighting circuit would randomly trip the mcb?
The maximum Zs tested was 1.07 ohms.
Its only ever happened (3 or 4 times) when the 2 wall lights in the front room are switched on. They both have energy saving light bulbs and none of them ever blow.
It doesn't trip the rcd, just the mcb.
Do energy saving lamps ever cause nuisance tripping?
I did a full insulation resistance test on the individual circuit and measured >299 on L - N, L - E and N - E.
The only other possibility is that the tv amp has been tapped off the lighting circuit but that has a perminant feed and not being switched.
If your still at college bud then good luck. However when i was there and testing I thought that was the norm as we were testing 3m or so of new cable therefore all results were that. Unless I got greater than 299m i assumed there was a fault.
Real life things are different though. Event after a full rewire global IR can be lower then 299m due to a number of factors. Therefore for you to have 299m. Either your not testing right or the install is in very very good nick
Excuse me for asking this, but if the TV amp is on a permenant supply off the lighting circuit how can you justify your >299 on L-N??
Domestic experience is very minimal as I am an employed as an electrical technician dealing with very expensive equipment.
Therefore I am not as good domestically as most people on the forum but I doubt many people would be as good as me at my job.
So no need to degrade me is there
So why don't you leave the safety of your fathers tenents to a professional then?
If it what a dead short as people have mentioned, then surely it would happened every time the light is switched on.
It's only happened a few times in the past week.
I will double check the insulation resistance tomorrow to be 100%.
Installation is probably 20 years old but cable runs are very short as its a small flat.
Reply to Lights keep tripping... in the UK Electrical Forum area at ElectriciansForums.net
A kettle boiling fish - thats your fault right there... or is it a red herring? :)
Check the clearance between the back panel and/or terminal cover that you've removed. Look for small burn marks.
