lights on timerswitch you push in block of flats | on ElectriciansForums
Discuss lights on timerswitch you push in block of flats in the Australia area at ElectriciansForums.net
i=p/u
Northern Ireland
a dude has just rang me and says the lights are staying on continuosly... i think could just be jammed... anything you'd like to advise me before i go have a look... i have never looked at these before and i said probably just need replaced.. he sqid if thats what it takes
If they are the ones I have used, they work on a vacuum. Push it in, you make contact and you have a vacuum, air is allowed in gradually (there is an adjustment screw to regulate the speed the air is let in) and when it is in or near the fully out position, the contact is broken. Age and dust is their biggest enemy.
Alternative is PIRs
Chances are the switch will be worn out and not just stuck. Yes, you can still get the pneumatic ones, there are a few places on line eg, but is your customer is willing to pay a little extra, get an electronic one as they are more reliable
cheers..... would you say they are all compatible... i cant see reason why not.... but maybe you can....they no differnt than intermediate switching if on 3 d 4 floors.?????
You are not switching off at any switches, so would suspect it is more like switches in parallel as you are only ever switching on - the switching off is automatic.
Hi mate, These pneumatic time delay switches are often used in the communial areas of blocks of flats and HMOs. The residents often don't like the lights going off automatically, particularly where the residents are OAPs with mobility issues, so it is quite common to find somebody has linked out the switch or alternatively jammed/glued the button in the ON position.
Matchstick up the side works a treat ! ;)
Reply to lights on timerswitch you push in block of flats in the Australia area at ElectriciansForums.net
Did it work?
