T
the glory years
Hi
I'm new here so be gentle. I have a reasonable knowledge of electrics and did an essential electrics course and my 17th Ed a few years ago. I have just tried to add 2 new lights from a feed from a bedroom lighting rose to 2 extra LED mains voltage lights off a seperate switch. After carefully locking off the mcb etc and wiring as per loop in, switch and loop out to 2nd light etc, they would only come on (via the pull switch )when the main bedroom light was turned off...? I can't work out why..? I know it must be obvious but it's been a while since I did any work (I'm looking to get some shadowing or trainee work as well) Anyone help ?
p.s the main light did have a low voltage lamp in it if that helps...
