Lights trip rcd when switch is turned off | on ElectriciansForums
Discuss Lights trip rcd when switch is turned off in the UK Electrical Forum area at ElectriciansForums.net
Np48qa
Hi, ive came across a fault today, the house has been rewired a month back and I was called today because the rcd would trip when the bedroom switch was turned off, it would turn on and work fine but as soon as you switched it off it would trip out, there is a standard pendant and single pole switch, insulation resistance checks out fine so im baffled to why this could be tripping.
have you tried it with no lamp in the fitting?
incase it is something else on the circuit?
Reply to Lights trip rcd when switch is turned off in the UK Electrical Forum area at ElectriciansForums.net
Thank you, what would be the advice for me to do in this scenario? I've also seen circuits tripped in past from other things such as 1500VA step...
Yea all out circuits were disconnected & Rcd ramped tested Think this will be the right way forward,with EL clamp meter Cheers have a nice Christmas 😎
