T
TPES
If you've been asked to asses for a board change in a house then a socket in a loft or a switch in a toilet should not effect you changing a CU. I would certainly write on the EIC that a periodic inspection is recommended. Then code faults, but your customer has not asked you to go around the house yet reporting potential faults?
You only need to asses the board change and then issue an EIC for the work your doing, which will be the change of the CU.
Maybe I've read you OP wrong
