It will certainly give the next sparkie on site something to think about !
Discuss Line and neutral same size? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Well until the regs change, I suppose like BS3036 semi-enclosed protective devices, they will continue to be permitted in installations. Whether or not this is aimed at existing installations or for new ones remains to be seen. Personally I wouldn't be too happy with reduced sized neutrals for many high frequency switching applications.
Well to comply with the regs its not that straight forward , if you have not assessed the loads including any harmonics and that neutral is not protected then this would be a departure from BS7671.
Reply to Line and neutral same size? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
