Link cable size new CU? | on ElectriciansForums
Discuss Link cable size new CU? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Danielwareham
Hi
What would be the link cable size be in a new CU when connecting a 80a 30Ma RCD to the neutral terminal bars and the live cable feed from the main switch to the RCD's?
Reply to Link cable size new CU? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Once you have designed your switchgear layout, You could try, New Circuit engineering, Close Engineering or Blackburn Starling to manufacture for...
