List of test... | on ElectriciansForums
Discuss List of test... in the Australia area at ElectriciansForums.net
Sparky12021986
hey everybody just need clarification to a question i think i got the right answer so here goes....
Q. List in the correct sequence the tests required for an installation to comply with BS 7671.
A. Continuity test
A. Insulation resistance test
A. Polarity test
A. Earth fault loop impedance
A. PSCC and PEFC if not determined by enquiry of the distributor.
A. Functional testing including, testing of RCD's and operation of all switchgear.
you just writting earth fault loop impediance, doesnt buy it for me, plus, ring final circuit conductors, and if was new install would differ from exisiting,
ring final circuit conductors comes under the same test as continuity, continiuty of conductors are to include protective conductors including main and supplementary bonding conductors, also ring final circuit conductors including protective conductors..
im getting proximity to electrical and other services,,, you wouldnt be using he book too older regs, hahah
your right to the on site guide, but this opens up completely when your a man, and what about vold drop..
your pretty dam close tho
ok your pretty much right
Reply to List of test... in the Australia area at ElectriciansForums.net
