Hi everyone just a little confused,when calculating volt drop using table 4Ab do you measure the voltage of the installation and use that value to calculate or do you just use the 230 volt value
Discuss little help with volt drop calc in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
not sure what voltage has got to do with calc for volts drop
Reply to little help with volt drop calc in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
