Search the forum,
Discuss Little League Baseball Pitching Machine Access in the UK Electrical Forum area at ElectriciansForums.net
tivotron
Hi there...seeking some advice on an issue for our local little league. I run the facilities... (NOTE: I will not be performing the work here, the licensed electricians from the city will)
We have pitching machines. I want to limit access to them.
Locking doors and power boxes doesn't work since I can't guarantee the coaches lock them up after they are done.
I'm hoping to figure out a way to turn on & off the power with Bluetooth access. The two outlets sit near the breaker.
This is the kind of tech I'm trying to replicate but for power on/off with a timer.
Give access to 50 coaches. They open the app, activate BT, tap a unit, which turns on the power on a timer, which then turns off after [30] mins.
Thank you very much!!!
Reply to Little League Baseball Pitching Machine Access in the UK Electrical Forum area at ElectriciansForums.net
