live joints in wall | on ElectriciansForums
Discuss live joints in wall in the UK Electrical Forum area at ElectriciansForums.net
scotland
hi there, recently had an electrician in as the kitchen was being re done now iam an apprentice didn't want to say anything to the guy who is qualified and of course and argument but hes left connector block joints in the plaster board wall with insulation taped up where existing sockets where and has joined the ring straight through which wont be accessible due to the plasterer coming also no minor works certificate I am not happy so come here for some advice reason for me not doing it is I expected minor works report which I cant sign off yet
thats rough as a badgers rear end.
What was wrong with him jointing with an maintenance free jointbox?
Is this your kitchen? Was he a proper sparky, or someone that the joiner sourced?
Where roughly are you located? maybe a forum member could have a look at it.
i agree iam not happy what so ever what makes it worse as half the db isnt rcd which i wil change myself but iam contacting the kitchen company pr iam going to report him to niceic this is just not on
  • [ElectriciansForums.net] live joints in wall
Two acceptable options.
1, Put it in a back box and then a blank plate over it. In your situation I'd prefer this as it remains accessible for inspection.
Or..
2, Use a Wago, or similar, Maintenance Free junction box and pop it back in the wall.
Taped up and thrown in the wall, whilst common, is very poor practice and may lead to issues down the line.
Picture 2 is an easy fix
pull back the cable from the socket to the right and remover , and there looks just enough slack on the other cable to push it into the double socket box and connect back to the socket
no need what so ever for the tape joint in this situation
Picture 1 , if you really don;t want a double socket there then I would put a box and blank it off
that's what I was going to say.
Or..
Can't say that I'm fully convinced about inaccessible maintenance free joints
Resin joint on a buried SWA ya
Haven't used the wago joint boxes but just sounds like glorified junction boxes to me .What happens if water drips down into the joint and it's inaccessible , I dunno
Or..
13 grand kitchen the spark will be back to fix it when I phone
Reply to live joints in wall in the UK Electrical Forum area at ElectriciansForums.net
It applies to commercial if it shares the same supply as a dwelling.
