Live neutral terminal LED bulkhead. | on ElectriciansForums
Discuss Live neutral terminal LED bulkhead. in the UK Electrical Forum area at ElectriciansForums.net
London
Evening everyone,
I had new one today, a live neutral terminal on the connector of a LED emergency bulkhead. This fault repeated on 4 other units.
The neutral was being taken from a 4ft fitting next door that a new guy had been messing around with.
Any ideas why or how?
Cheers
[ElectriciansForums.net] Live neutral terminal LED bulkhead.
A N terminal will always become live if the following are true
Live is connected to to corresponding live terminal of the load
The load is switched on
The N terminal has become disconnected from supply N.
Watch out, one of the floating N cables is likely to be live as well.
Looks to be a loss of the Neutral, I assume the fitting wasn't working.
If you disconnect N from an energised working circuit, you would expect to see voltage on the N connector of the fitting.
Leaving hanging conductors like that isn't a good idea either.
Reply to Live neutral terminal LED bulkhead. in the UK Electrical Forum area at ElectriciansForums.net
I have an "old school" electricity monitor similar to this one...
Sounds more positive.
