Live side | on ElectriciansForums
Discuss Live side in the UK Electrical Forum area at ElectriciansForums.net
M
Marlow
Good evening,
a colleague of mine wants to install a sub main into the liveside of a mainswitch in another board.
Can people please provide me a answer if it ok or not
thanks
Too many variables to give a reliable answer.
IF the main switch terminals are designed to accept two conductors, and IF it is already fed from a submain and The new cable is the right size for the OCPD of that submain. Also if that existing submain has spare capacity to feed this new submain then it might be ok.
Thanks for the reply
The board is a small board 63/100 amps fed from around 60/70 meters away.
the supply for the new board is 63 amps.
Personally I think it shouldn't be done but designer said it is ok
Not really, you should have a single point of isolation, and whilst it may be possible to fit two sets of tails into the switch (2X25mm² is a bit tight even on a 50mm² capacity terminal) it is not good practice.
Use an isolator and a Henley block.
You're assuming its a 100A board at the intake then?
If it's already fed via a submain then it is possible.
It will be coming from a large board located in switch room cannot gain access at the moment
Richard it is been added onto the plans so we will be covered but I am questioning it because don't each circuit need a way of isolation
so is the existing cable suitable for the added design current of the new board? What about terminating the existing into a switch disconnector and then taking two feeds to the separate boards?
The cable is should be suitable as we need 63 amp supply
I think I will advise the disconnector option as the small board they want us to come off is redundant
Reply to Live side in the UK Electrical Forum area at ElectriciansForums.net
Has the cover been removed, is it TP bussbar? I fitted one as @oscar21 linked to a few months ago, it was actually a nice board and with the TP...
Jumping on and off jobs can be tough going when you're less than confident as every time you go back it's like a new job. that you know little...
nicebutdim
N
