LN to eath IR test | on ElectriciansForums
Discuss LN to eath IR test in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
just a quick one
if i did a insulation resistance test between L N (together) and earth would i still need to disconnect bulbs and voltage sensitive equipment???
cheers in advance
Reply to LN to eath IR test in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
There can be a few reasons for low L+N -> E readings: Connected equipment is leaking. By design, or just old/damp SPD are connected (but there...
Not all sockets isolate both the live and neutral when you turn the switch off Many just isolate the live leaving the N connected. So the...
