load close to source | on ElectriciansForums
Discuss load close to source in the UK Electrical Forum area at ElectriciansForums.net
Na, my fault, being too short with replies as its a holiday and Queen is on the tele.
I find if you place a remote stat in the room you get a much better heat control and 4KW is a burden for stats and timers and a contactor is only ÂŁ8 so that why i suggested it.
We will , we will , rock you.... BBC4 :biggrin5:
thats what i thought what is it ? a contactor a separate timer
check the thread about simply installing 2x 2 kw heaters into someones home
"load to close to source"
contactors runnin of ov timers....
well once when we went to this place...there were chipboard squares with these on em...together with a load of 2 gang fronts...lol
yep, you guessed it...GROWERS....lol...
Reply to load close to source in the UK Electrical Forum area at ElectriciansForums.net
The light may have a permanent supply already inside it if you are lucky.
Hello All, This is Vaithees from India. We are using an IR heater for a vacuum & non-vacuum chamber and got a heater from Chinese company and its...
