I am installing two 2Kw convector heaters in a small flat. The obvious way would be to connect them to the ring, especially since they each have a 13A plug. However 4Kw sounds a lot to me on a ring. Its rather more than an immersion heater! but on the other hand no where near the 7.3Kw for which the ring is designed, on the other hand it may or may not cause an imbalance in the loading of each leg or the ring,
If I were desining this from scratch then obviously they would have their own supply, but I'm not! There again if I run seperate supplies it would have to be in trunking along the hall ceiling, not very elegant. There are so many variables I'm undecided. What would your take be?
