Local ad near me | on ElectriciansForums
Discuss Local ad near me in the UK Electrical Forum area at ElectriciansForums.net
stan794
Seen this ad today in my town, what a turkey.
"Upgrade your consumer unit (fuse box) & help keep your home & family safe.
Supplied, installed, certified & a 5 year guarantee - ONLY ÂŁ180"
cheap chinese imported equipment with a visual inspection only, but then he will want extra to upgrade tails, add bonding etc. Then extra to fault find when the RCD/RCD's will not stop in! They will be left with a bill for ÂŁ500 +
Which means nothing without a town. Give him a ring and see if the bonding and faults fixed are included too. lol
I suspect those items would be extra on any CU board change!!
The bonding and fault finding will, or should be known about after initial visual inspection and a preliminary short testing sequence. From what i have read here, most electricians specifically exclude remedial works that may be required for, or after a CU upgrade....
before dont you mean..
Reply to Local ad near me in the UK Electrical Forum area at ElectriciansForums.net
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
Why go to the trouble of adding another cable, which I assume would follow the same route as the other ?. Why not upgrade it. It was to try to...
