M
mattcos1972
I have a customer asking if I can fit a shaver socket in the cupboard under the sink in their bathroom.
Is this acceptable?
Is this acceptable?
Discuss Location of Shaver Socket in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Is this acceptable?
Dont see any reason why not.
Nothing wrong with that at all. If I can have a mains socket under my sink in the kitchen he can have a shaver socket in a cupboard. Dont forget if the cupboard is lockable or needs a tool to open it then its outside the zones if I remember correctly.
Chris
Hopefully with no water pipes in the middle
Chris
Thanks Jason. That's what I thought. Seems the safest place in the room to be honest as its quite a small room and there's a mighty powerful shower close to the sink area.
Also, I know they are usually powered from the lighting circuit, but its OK to power it from a nearby socket on the upstairs ring that's backing onto the same wall isn't it? Its an RCD protected circuit.
I can drill straight through the wall into the back of the cupboard...nice and simple!
Seems like a good idea. I would check that it is Ok to wire into a circuit of more than 6 amps, or you may have to fuse spur it.
Why not just spur from the RFC in 2.5 into the shaver socket?
Reply to Location of Shaver Socket in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
