Lockable/Vandal proof fused spurs | Page 2 | on ElectriciansForums
Discuss Lockable/Vandal proof fused spurs in the UK Electrical Forum area at ElectriciansForums.net
B
benieb
Hi I need some unstitched fused spurs that are to be insalled in a challenging location that has a history of misuse and vandalism.
Has anyone come across any spurs that the fuse cannot be easily removed or a lockable enclosure to fit a sput into.
many thanks,
Nothing so say that the fuse carrier has to be removable from the outside - what about using blank metal clad boxes with in-line crimp fuse carriers (the auto style ones) inside, and security screws? BGB does actually offer you a large amount of latitude in things like this.
I can't think of one to be honest, the only solution which may or may not work depending on space is a MEM 32 amp metal clad switch fuse, you could change the BS1361 32 amp fuse to a 13 amp and you can actually padlock these switches, they are however around 8" BY 6", however they will do the job, there is a metal handle which you can lift up to switch off and down to a 90 degree position to switch on, the padlock locks between the metal circle surround and the handle, you need to ask your wholesaler though as some of the switch fuses have no metal surround and are not lockable, heres a link it is not an mem, but very similar, Contactum TP&N Switchfuse 20 32 63 100 160 200 250 400 630 Amp as you can see they are lockable although large, perhaps this could be a solution
Kind Regards
Michael
Reply to Lockable/Vandal proof fused spurs in the UK Electrical Forum area at ElectriciansForums.net
