Hello,
I am having issues getting my head around this.
So, I want to install a single ceiling light and switch in the loft.
The loft access is in the middle of the upstairs landing.
There is already downlights across the whole of upstairs landing.
Therefore there are T&E cables up in the loft looping in and out of each one.
Please kindly correct me if the below process is wrong.
I was thinking cut split the wire from landing switch to the first downlight, adding wago connectors to connect the split wires, first downlight wire, and a new 1.5mm T&E cable of new switch for the loft light - All into 1 wago junction box.
Then connecting another 1.5mm T&E cable from the switch to the light. Done.
Is this correct or completely wrong?
Many thanks,
Topia
Many thanks,
Topia
