Hi all,
I’ve recently had my boiler moved from the kitchen to the airing cupboard upstairs. (Changed to combi)
Prior to this the hot water tank was in the airing cupboard which was being powered from its own circuit on the consumer unit. There was a shower pump powered from an FCU running from the hot water tank circuit.
The current boiler is run off the same circuit on a 3A FCU. The actual circuit is only powering the FCU at the moment.
If I wanted to put an LED batten light in the loft which is directly above, could I run the light from the boiler FCU? So the LED light and boiler are on the same FCU.
The loft is fully boarded so don’t want to cut into it to get to the light circuits.
Many thanks,
J
Many thanks,
J
