Loft wiring advice please | Page 3 | on ElectriciansForums
Discuss Loft wiring advice please in the UK Electrical Forum area at ElectriciansForums.net
Andyx
Brighton
I am fitting a Nuaire Drymaster PIV into my loft space. I had it fitted in another house and it as it is max 15.3W and protected by a 1 Amp fuse was wired into the lighting circuit. I don't feel confident to do this through a junction box etc but there is loft light which I could use the wiring from easily - I just wanted to check is there a way I can do this without loosing the use of the light. As the the Drymaster has to stay on I assume I couldn't have both (without wiring direct from a junction box)?
cheers
He’s gone to Screwfix to ask there.
I'ts funny you should say that....
I used to work at a plumbers-merchant for many years. baring in-mind I had no plumbing qualifications at all, the qualified-plumbers used to ask me all sorts of questions from heat-loss calculations to BTU, etc. I always responded politely by saying "I'm not qualified and you should consult a qualified contractor for advice, here's someone that can help...".
Moral of the story, if you want recommendations, keep the merchant on your side! :)
Reply to Loft wiring advice please in the UK Electrical Forum area at ElectriciansForums.net
I'm familiar with many domestic extractor fans which are primarily class 2 (double insulated) and consequently are not required to be earthed...
I don't really know if he is or not, but I would have thought an electrician would be able to calculate cable size or know about requirements for...
