Discuss Log cabin supplies in the UK Electrical Forum area at ElectriciansForums.net
For volt drop 35.0 in undersized.Multicore 90°C Armoured Thermosetting Insulated Cables
Tables Apply to: H6942XL, H6943XL, H6944XL, H6945XL, Tuff Sheath,
Voltage:400V
Load:44.34kW / 80A
Length:190m
Method of Installation direct in ground or in ducting in ground
Cable Size:35mm²
@westward10 point is that is when you have a balanced 3-phase load so only the losses in L1-L3 are a factor as N current is near-zero, if you have just one cabin drawing 80A then you get double the drop (L & N losses) so I'm guessing that is the 8% mention above, but I have not actually checked it.That calculated from Cleveland cables.
noooooooooo190m run SWA underground, supplied from 3p+N 240mm sub main, each cabin total demand is 80A, worked out 35mm but volt drop is about 8%, would this be okay?
Reply to Log cabin supplies in the UK Electrical Forum area at ElectriciansForums.net
