Log cabin supply | on ElectriciansForums
Discuss Log cabin supply in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
suke
Mate was asking for some advice.
He is looking to put a 100 amp supply into a log cabin he is having built in the middle of nowhere. He has spoke to the electricity board who have said that there is a pole mounted transformer supply approx. 350 metres away from where his log cabin will be sited. He has to build a brick "shed" to house the metering etc adjacent to the pole and then run his cable from there to the log cabin. I estimate taking into account volts drop etc he needs a cable size of 185mm. Obviously a bit big for your average consumer unit! What would you do?:confused:
You could inquire to see if the Electricity board might extend their network :) would cost a fortune me thinks, so would laying 350m of 185mm I suppose. If it's not going to be inhabited all the time how about a localized generator.
More likely cheaper to move the cabin nearer the pole:D
Does kinda make you wonder why we have to use cables the size of tree trunks for this sort of thing but the supply companies get away with a bit of wet string run for miles.
If it were me i'd be asking the mountain to come to me not the other way round,thats a very long expensive run.
has the guy who owns the cabin got any land around it with eleci supply poles on it?
its a good negotiation tool if he has.
i've worked on construction of 1,2 & 3 bed log cabin houses .
does he really need a 100amp supply ,log cabins don't take much heating as the combination of timber and mega insulation is as good as it gets.
most people fit a small log burning stove .
how many bedrooms is you friends gonna be?
elfyn
Reply to Log cabin supply in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Yes, that was actually something making me uncomfortable too, the bonding of it all. I need to have another look at it, I'm not sure if the...
