Logic Outputs Problem in 7493 IC | Page 3 | on ElectriciansForums
Discuss Logic Outputs Problem in 7493 IC in the UK Electrical Forum area at ElectriciansForums.net
_q12x_
New York
Hello from Romania.
I have all the counting ccts, for every number. This is counting to 16 and its the last one this 7493 can count.
I encounter a new and very weird problem. All the [Q] (QA,QB,QC,QD) outputs of the 7493 are not so good at outputting. At least to my components I tested so far.
[ElectriciansForums.net] Logic Outputs Problem in 7493 IC
I simulated more possibilities and all failed. I thought maybe the simulator is not that good. But when I tried the BJT in reality, it still didnt work. I really want to believe it will work with opamps in reality, but if it will not work, it means the simulator is right.
I didnt try with mosfets in the simulator yet, they were just prepared there. I didnt test them in cct.
THe problem is the (-) that 'comes out' after these buffering devices. When they are on (-) on their output.
I actually solved the problem using a tri-state buffer. They are the only component that are solving this issue.
Ive also get 10 pcs from aliespress. I start to value them now, when I actually need them. But they will arrive after 2 or so months from now.
- I want to find a solution (IF POSSIBLE) without them, or at least until they arrive.
This cct I already make and it is working fine (in the simulator) is to output a decimal number for all the 16 binary counts.
Pretty much when is 0100 it will lit the 4th LED. When is 1000 the 8th LED and so on, from 1 to 16 (including 0).
You can see in the screenshot already.
I work on this cct and numerous problems for .... about 10 or more days. Very hard to do it alone !!! But I did it. so far.
I even have an easier output method than this very complicated cct I already built.
- Simply to display in binary. Like these 4 LogicProbe from Proteus simulator that I am always take for granted.
So we can do these first !
To make a simple binary counter [LED display], I will still need some sort of buffer, like the ones I specified already.
I wait for your response. This is a very complicated cct and a big problem for me.
Thank you and hope I will get some interesting answers! (mister @marconi , my Logical friend?haha)
And also Happy New Year 2023 to everyone that are reading my posts !
Earlier on, in your frequency counter post, we covered the unsuitability of diode resistor logic for AND or OR when used to detect a counter state and generate a very fast rise/fall and short duration reset pulse to RO1 and RO2 of the 7493. Because of the capacitance between anode and cathode of the diodes the circuit is too slow to produce one short clean reset pulse. Do you remember now? We had to use a semiconductor AND/NAND ic from the 74 or 40 series.
I managed to make this thing work in reality !
The (right) 4 logic probes here in the image are LEDs in reality, counting in binary.
This setup here is the same as the diodes one (but way more complicated)
The only problem is that I dont have any other 7430. This was the only one. And is most probably a slow TTL version, very old and made by romanians somewhere in 80's. The good news is that everything is working. Well, until the end of these 4 lines.
I just measured all the Buss lines and all the outputs and inputs and I pretty much get the same result as with the diode version.
VERY STRAAAAAAAAAAAAAAAAANGE!!!!!!!!!!!!
The only difference now, is that I can use those 4 leds counting in binary on the buss line.
But everything is UNDETECTABLE on those 4 bus lines !!! yet, it is working.
AGAIN> VERY STRAAAAAAAAAAAAAAAAANGE !!!!!!!!!!!!
Why I cant measure them? I still get a very WEAK signal, close to gnd.
Maybe I dont know how to measure this thing? How in the hell are you measure such thing?
AGAIN> VERY STRAAAAAAAAAAAAAAAAANGE !!!!!!!!!!!! WOW.
Indeed, and thank you that you watched my movie.
I just revert back to the diodes instead of the 8 input NAND and it is working....but for certain counts. Up to count to 8 everything works. But AFTER 8, is giving me errors. So the diodes not good in the logic side. I put back the 8 input NAND and tested every count. And I get this result:
Which is great news. Also the binary counting leds are doing their jobs fine, and also for the moment that single #1 module display also did it's job for everything so far.
I was thinking to replace this 4xAND diode gate with a 4input DTL NAND and a NOT also DTL.... But I will see.... What do you think? Should I ?
Next...probably I will have to make all the display #'s and see what 's*it' I will get from there.
This long tutankamon:
This is how is looking now in reality and is also working in the simulator as well with minor changes (R9) and some errors, but is working.
As you can see, no transistors on the BUS. Directly from the 7493 !!! Which Im not really a fan, but, it works.
I will check your posts but today and tomorrow I am visiting my elderly parents so I have less time to contribute(?) to your project.
I do not think you will be satisfied unless you test your Dtl logic gates first. You may need the source and sink circuit I sent you a diagram to drive 16 of them.
Im on the wave !
I managed to make the analogue version of a NAND Gate +a NOT Gate !
Tested from 2 to 16, all working as with the real chips.
Excellent !
Check the picture in the bottom of it.
Im starting to make the (card)boards for the 'display' counter (0-15).
Very retro looking and feeling.
A lot of work. I only finished #1 module and tested on my breadboard and working and I have a GO for the rest.
Hope you like it.
Reply to Logic Outputs Problem in 7493 IC in the UK Electrical Forum area at ElectriciansForums.net
This controller might do the job if you have single colour strip. You'll still need a power supply prior to this! Lots of additional features you...
My bafflement increases. I swapped the offending light with one elsewhere on the back of the house - one of those that's on a circuit of its own...
