I've got a set of cheapo step drills from small stuff to bigger stuff (25-32-40), managed to file the stem down enough to fit in my drill now, happy days, just need to go slow with it. Didn't want to but needs must ?
I'm with the hole punch brigade on this. Used a 20mm on a metal shed the other day and it was so easy, no drama, took less than 1 minute, and the "slug" will make a useful washer for something...
Whats the point of a punch when you have to drill anyway?????
  • Cleaner hole edge
  • Less swarf flying around
  • Sometime you have an existing hole too big for a hole saw you need to extend
  • Can be used in some cases where you have insufficient access for a big enough drill for a hole saw (for larger sizes really).
For general installation work not much really
For making an existing hole bigger, especially when you need it to be off-centre to the existing hole they are good.
Also they give a more accurately sized hole of you are mounting connectors, buttons, indicators etc into something.
Liverpool
Business Name
Home Security Systems NW
looking for best step / cone cutter for using on 18th edition consumer units
Electrical Tools and Products
TartanSparky,
davesparks,
