Looking for Extreme Extractor Fan with Max m3/h | on ElectriciansForums
Discuss Looking for Extreme Extractor Fan with Max m3/h in the UK Electrical Forum area at ElectriciansForums.net
E
eur-gbp
I need a massive air flow for my server room aka metal shipping container 6m x 3m x 2.5m
Found this but it is huge and heavy and expensive, are there any other options?
I need something compact like a turbine with duct with enormous air flow per hour
Industrial Extractor Fan 500mm 230v 1400rpm 9000m3/hr 2 year warranty ÂŁ273.60
That is 200 air changes per hour. You would be better working out your inputs, efficiency and therefore your heat produced, max and min air ambient air temp to determine your actual cooling requirements and putting in air con. Unless you are somewhere really cool. Pumping through air at 25C when you are trying to keep the temp at 20C will not work well. And we do occasionally get temps that high in the UK although I can't remember when :)
......and a shipping container will not provide any shading effect. In fact it will be an oven whenever the sun pops its head out. (You may know this already).
I agree. air con is your way forward.
This handy page gives you a rough guide on how large a unit you would need.
http://www.which.co.uk/home-and-gar...ectricity/guides/how-to-buy-air-conditioners/
Cost will be more than the fan you linked to.....:eek:mg_smile:
Reply to Looking for Extreme Extractor Fan with Max m3/h in the UK Electrical Forum area at ElectriciansForums.net
