Looking for spotlight suitable for used fireplace | Page 2 | on ElectriciansForums
Discuss Looking for spotlight suitable for used fireplace in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
You can make a bespoke set-up,using oven equipment,but it would be a lot of effort,just to have a better view of a flue...
My choice,would be a clear,pyrex flue,and some magnesium,mixed in with the logs...
You could use a 12v MR16 halogen downlight lamp with the transformer mounted remotely somewhere cool and fibreglass insulated wiring in fiberglass sleeve between the lamp and the transformer. I've seen this set up in fireplace chimneys on several occasions but I'm not sure how much longer the halogen lamps will be available.
Ive fitted gu10 spotlights in corners of large fireplaces with no problems, brought wiring in from side into back of fitting, where ive had to run accross fireplace used fp with p clips, no problems.
Mountain of a mole hill springs to mind from some posts.
I have given you a disagree .... on the basis that you have made it out as if every body with a wood bummer can do this .... we can’t.... our fireplace simply isn’t big enough
About to install a double sided wood burner after knocking through two back to back fire places. Thought about fancy lighting but now finished :D
Could work with a bit of stockpiling thanks
Reply to Looking for spotlight suitable for used fireplace in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
I challenged a council on having the same system installed in an HMO. One consideration is if the flats/escape route were made to The Building...
Hi All, I am looking to start installing commercial fire alarms, I want to be able to design, install and commission. I am a member of NICEIC so...
