Looks a squeeze, 240 swa thoughts. | on ElectriciansForums
Discuss Looks a squeeze, 240 swa thoughts. in the Talk Electrician area at ElectriciansForums.net
LeeH
Lincs
Have a 250kW motor with the terminal box in the photo. To me it looks a proper squeeze to bend in the conductors.
Thoughts?
Other options I can think of is allowing the use of SY on this cable only or parallel cables.
[ElectriciansForums.net] Looks a squeeze, 240 swa thoughts.
I have absolutely no experience of cables that big, but if I was asked to do it I might be inclined to do a bit of a switch around, so left cable to right terminals (I'm guessing there is going to be two cables as there are 6 terminals) and vice versa to give myself a bigger bend radius.
Please post up a pick of it when it's done :)
Thoughts?
You try, tri rated conductors.
Cannot get them in Pete, ATEX. Have 2 M75 holes so cannot mod the box.
Where did the 240mm2 SWA calcs come from? that's a big old cable. Ignore please I got my sums wrong
Am I right in thinking with VFDs that it would be a three core cable, with the motor connected in star formation?
Edit:- I'm thinking it may be dependent on the driver itself.
Not sure a motor that size would be started DOL
Yes, a VFD cable should be symmetrically arranged, no 4th core.
1 cable, 3 cores to this motor. 3 if you include the CPC and thyristor cable.
I think the VFD would gradually ramp up the frequency and applied voltage over a pre-programmed period of time or at a pre-programmed rate.
I'm trying to learn abit about VFDs as I've got a sneaky feeling one of the farmers I do a bit of work for has one on the feed mill he's wanting to get connected up, so I'm doing a bit of reading around the subject ahead of the inevitable "it don't work chick, can you come and have a look at it for me" :)
Perhaps some combination of angled / cranked lugs, so the near one goes straight, the next one is slightly cranked, then the far one kicks up to the lid of the box at 45° and overflies the first two.
If permissible, an additional pre-formed copper link to offset one of the terminals, or even a flag terminal if a suitable one can be found, could allow one core to go on the outside of the studs.
Could you get an extension box made to give you better accessibility, maybe make it higher, and use angled lugs.
Reply to Looks a squeeze, 240 swa thoughts. in the Talk Electrician area at ElectriciansForums.net
Sounds more positive.
Thanks, I was hoping someone could confirm whether it was odd or not. I've done a fair bit of insulation testing but only on a small number of...
