sivoodoo
Which method would you think uses the least amont of cable, looping in at the ceiling rose or at the switch?
Regards
Si.
Regards
Si.
I almost always fit a 35mm box. I've easily managed to fit 8 cables (2* feed's, 3* switch lives and 3 3core's) into a single 35mm backbox no trouble, dress it in all neatly and it will push in like a dream
Way too much like hard work for me! How on earth do you contain 8 cables in a chased out wall? Must be a right old mission!I almost always fit a 35mm box. I've easily managed to fit 8 cables (2* feed's, 3* switch lives and 3 3core's) into a single 35mm backbox no trouble, dress it in all neatly and it will push in like a dream
So ....no containment at the down-lighters for the building wire loops, ...really, ...OK , lol!!!
At a single 1 way one gang maybe, but that's not always the case is it, especially in hallways/porches etc!! The last thread on this subject someone actually posted a photo of a switch looped switch, it looked as if you would need to force the dammed switch plate back into the box. So not my imagination at all!!
What you may call a satisfactory answer, is not necessarily anyone else's! I think i've made my position just about as clear as i can, if you don't agree that's fine too. I'm not telling you how to wire anything, you've been in this game long enough to decide that for yourself.
A perfect example!! I Rest my case!! lol!!!
And very good advice too!! But then, ....just how often do you see electricians these days spending more time chopping out for those deeper boxes?? Not very often is it!!!!
3G switch with feed in, feed out, switch line 1 switch line 2 switch line 3 and a 3 c to another 1 g switch somewhere for a 2 way == still only one 6 way wago block for 5 neutrals.
i always chase out 35mm boxes for all single boxes, gives me the scope to use feed in feed out on switches if i like and also is a better depth box for fuse spurs in kitchens where you have got 3 2.5mm in the boxes, i also use 47mm boxes for shaver points and cooker switches/outlets.
jase;383172. if you are not using 35 or 47mm boxes then you are squashing 3 x 2.5mm for a fuse spur into a 25mm box? or 6mm's into what? a 25mm box too??????[/QUOTE said:Thought we were talking about ''Loop in at ceiling rose or switch'' So what are you on about here??
