Losing power to house post meter upgrade?? | Page 4 | on ElectriciansForums
Discuss Losing power to house post meter upgrade?? in the UK Electrical Forum area at ElectriciansForums.net
lurch
got called back to a rewire I completed 5 years ago. Customer reported intermittent loss of power across the house. I have a swa sub main from a 63amp switch fuse to the CU. I have checked all terminations at CU and switch fuse . . . . all good. Have thrown thenmain switch 4-5 times to see if it is faulty but all seems good.
Customer has advised new meter was installed 5-6 weeks ago . . . Ive given tails a good tug to see if there is anything amiss, but nothing to suggest any issues.
Has anyone come across a faulty meter that could be causing the issue?
Thx in advance.
Noreen ceased to exist many years ago! I should know, I worked for them. We then became United Utilities then ENWL. The meters may have the old Board names on them but the DNOs don't own (or want) them. They were transferred to the suppliers.
Should be Norweb!
Reply to Losing power to house post meter upgrade?? in the UK Electrical Forum area at ElectriciansForums.net
If you have an EV the EV charger will also log the supply Are there current transformers on each phase?
When I was on the electric board We had a pair of pillocks connect a housing estate to a very large genset, the n lead was in two parts and not...
4K
