Lost trying to wire contactors and timers | Page 2 | on ElectriciansForums
Discuss Lost trying to wire contactors and timers in the Australia area at ElectriciansForums.net
Ive got a 20amp 2 pole proteus din rail contactor
Proteus - Products
and proteus 16amp 1 mod din rail timer....
Proteus - Products
Hoping to use for night day switching of a selection of flurorescent (7 x 70w )and downlights (12 x 50w)with a total load of about 6 amps/1482w.
Thing is not quite sure how to go about the wiring...
I was going to have a 6 amp mcb supply the timer and 10 supply the contactor and 10 amp supply the lighting...is this correct? Was advised to have each seperatly supplied....
But now i lost the plot a bit on how to wire as no good diagrams..NOt knowing what numbers do what ie where neutrals go and load side etc ....
i dont need any switches just to be switched by timer...
Also is it ok to have all mcbs on RCD?
Sorry its a bit of long winded one guys but been a while since had my head in this.....not good really....
many thanks
Easier to work from drawings nice one Jud , cant say more than whats been said ,but would just like to add when calculating the wattage of flourescents if the fittings are switch start with the ballast you have a correction factor of 1.8 so the loading will be higher IE, 7 x 70 watt = 490 x 1.8 = 882 watts / 230 = 3.83 amps so add that to the down lighters = 600 watts / 230 = 2.6 amps + 3.83 amps = 6.43 amps so as has been mentioned you will require a 10 amp MCB or split over more than one circuit as the diagram says
Reply to Lost trying to wire contactors and timers in the Australia area at ElectriciansForums.net
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
