Low Glow on LED's | on ElectriciansForums
Discuss Low Glow on LED's in the Talk Electrician area at ElectriciansForums.net
United Kingdom
Hi can anyone help.
I have installed some LED's in my bathroom and a fan which has a time delay on it. When I turn the LED's off I noticed they still have a Glow to them, so I put my Multi accross one of them and there are 103v present when switched off. If I disconnect the switch wire to the fan the voltage disappears. Can anyone offer any advice as to how I get rid of the voltage feedback from the fan???
Yes all through the fan switch correctly, the LED's are Minisun Warm Whites... there are alot of electronics in the fan I'm wondering if it is something in the fan that is causing it... I dont know really.
Phil measure your "phantom voltage" with an analogue meter if you have one, if it disappears when doing this then you need a snubber.
Hey, Yes it does disappear, so please tell me, what is a snubber? Cheers
The subject has been done to death on here, search for terms such as "snubber" and "phantom voltage" etc. on here and this will explain all, there is a search forum box at the top of the page near where you sign in.
Hi S68 :smile5:
We seem to use the terms 'Induced' and 'phantom' interchangably.. Is that correct? One seems to imply that there really is voltage there (i.e 'induced') and the other suggests its not. If it makes the bulbs glow then it must be there? :uhoh2:
Reply to Low Glow on LED's in the Talk Electrician area at ElectriciansForums.net
Similar queries here previously, eg: Advice (please) regarding suppressor / "snubber" for LED lighting | on ElectriciansForums -...
Neutral and live
