P
pvman
Have a problem with a customers array as both the Power One 27.6tl and the 20.0tl are registering low Riso faults. The array has been earthed on the roof and is made up of Renesola 255s. When tested across the +ve and -ve of each string to earth the same voltages were obtained for all strings on the different trackers. Also the same voltage across the -ve and earth was found to be the same on all strings.
I am wondering if anyone has any ideas
Matt
Matt
