Low RISO fault | Page 2 | on ElectriciansForums
Discuss Low RISO fault in the Green Lounge (Access Only) area at ElectriciansForums.net
changed all the MC4 connectors and their panel equivalent. Still had an issue with the larger inverter and ended up having to slightly reduce the RISO setting.
Thanks pvman, that is very helpful. We changed all the MC4 on a split array system yesterday and managed to push the fault from on array to the other. Our feeling is there is more to this than wet MC4. We inspected each of the MC4 and they looked far from wet internally.
Reply to Low RISO fault in the Green Lounge (Access Only) area at ElectriciansForums.net
Hi all, This may is a little odd and may take some getting your head around but here goes... I measured around half the load current on two DC...
I created a voltage drop spreadsheet for this sort of thing. I used to use it to calculate the drop when designing regular 230V lighting circuits...
