Low voltage between live and neutral | Page 2 | on ElectriciansForums
Discuss Low voltage between live and neutral in the UK Electrical Forum area at ElectriciansForums.net
M
Marks Electrics
Hello, ive just been to look at a job with a light not working, after checking found voltage between live and neutral is 170v, between live and earth is 230v, is it just a case of a neutral issue, eg, loose connection, water ingress any suggestions would be great, cheers
Reply to Low voltage between live and neutral in the UK Electrical Forum area at ElectriciansForums.net
One of those backlight Chinese testers may have helped that’s if the tester didn’t catch fire or electrocute you. LED TV Backlight Tester 12W LED...
2 3 4 5
5K
There could also be a completely unsuitable junction box embedded within the wall and tiled over or just cables in choc blocks in old accessory...
