mrloy99
- Joined
- Dec 21, 2008
- Messages
- 473
- Reaction score
- 18
This guy I used to work with years ago in australia had his house all running off a car battery,and used to bring it into work once a week to charge it up when the boss wasn't looking.I was thinking of fitting a transformer near the consumer unit and supplying all the downstairs lighting circuit with 12v and changing all the fittings. Has anyone done this and is there any likely problems.
I got to be honest I dont think you can get a 12V transformer with a big enough VA rating to do an entire circuit.
I've never seen one. Do you have one in mind??
I once took a 500va out of a shop that was being refitted,it weighed about 10kg....I ended up useing it in a barn conversion rather unorthodoxly.(but as it was in northern ireland it looked ok) But,on the low voltage side I came out in 16mmsq feeding 2 lenghts of BARBED WIRE.low voltage lampholder cables connected onto the barb with standard 15amp connector blocks.I had fourteen 35watt 12volt lamps running off this.This was 10years ago and as far as I know its still going.
