C
caithpal
Hi
I have a set of low voltage under unit lights in my kitchen as well as a set of 240v dowlighter on the ceiling. Both sets are controlled by a switch (2 gang - 1 switch for each) on the wall.
Last month the switch on the right hand side which turns the under unit lights on and off stopped working and I could not turn on my under unit lights (it had worked normally for 2 years). I did nothing about this for a few days and then suddenly it started to work normally again. Some days later I noticed that when I turned the lights on they would not turn off. I tried turning off the power at the mains and that became the only way for me to turn off the under unit lights at night!
I then decided to replace the 2 gang switch on the wall with brand new 2 gang 1 way switch but realised that the one installed is 2 gang 2 way. I did this replacing the wires exactly as per the original installation to ensure I didn’t mess up. I assume now the reason the low voltage set was on a 2 way was that one half of my under unit lights have a small switch on the side of the light unit to allow me to turn off that half of the lights? I can’t turn the lights on with that small switch – just turn that half off.
This made no difference – same fault and the lights would never turn off! I was getting sick of isolating the downstairs lights each night and morning by this point.
I then investigated the transformers on top of my kitchen units and disconnected them all (the little plastic plugs that feed to each lamp). This worked so I now don’t have any use of my under unit lights.
Any ideas how I can fix this? Is it the lamps that are causing this permanent on state or the transformers, or the switch? I find it hard to believe that I have bought a switch that has the same fault as the one that worked fine for 2 years! I have attached a picture that might help?
HELP!
HELP!
