Low zE reading! | on ElectriciansForums
Discuss Low zE reading! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
South East Kent
I have testing the ze on a flat on a tncs supply, and i am getting a reading of 0.03. I realise the maximum is 0.35 but this seems low to me. Has anyone else experienced a low ze reading. The flat is situated quite close to Sub station so I expected lower reading.
With a low Ze the only issue is the resulting pefc and pfc......as long as these are within the rating of the protective devices all's good.......in your case expect a pefc/pfc of 7-8ka.....which means you may have to rely on the DNO device to provide the breaking capacity.
Yes dont worry about it , i bet you had a High PSC reading too, low readings are normally due to the installation being close to the sub station or transformer and the PSC will be at its highest
Reply to Low zE reading! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
For what OCD? There may be other means of over current protection that allow a Zs of0.45 (HRC Fuse?)
I was at the other end of the results spectrum today. As I was driving home I had a call from my "Mrs Richards from Fawlty Towers" lady, very deaf...
