Discuss LPG Bonding in the UK Electrical Forum area at ElectriciansForums.net
Is there a storage tank in this LPG set-up?? If so, then the tank will need earthing, (usually a rod or other TT electrode) so that the filling tanker can connect it's equipotential conductor to the tank. No earthing and many drivers/operators will not connect the LPG filling pipe to the tank....
With other chemical storage tanks I’ve dealt with the delivery driver will connect a bond first. Delivery can then commence. So long as the storage and delivery tanks are connected first it doesn’t cause a problem.
The biggest problem was the tanker driving off with the bond still connected. Had many a driver in the workshop wanting bonding and power cables repaired.
Reply to LPG Bonding in the UK Electrical Forum area at ElectriciansForums.net
