LSF cable | on ElectriciansForums
Discuss LSF cable in the Australia area at ElectriciansForums.net
The only 'guidance' I've seen mentioned assessing the risk as in ease of evacuation, complexity/size of building etc.
Regulation 422.2.1 covers escape routes and Low smoke cabling.
Personal opinion, when you look at how much PVC containment etc. is used and what state the building would probably be in by the time the burning wiring system became a serious concern, there might be some 'hype' going on with LSF.
I know of a contractor who has recently completed a steel conduit and PVC singles installation in a school and has has rip old wiring back out and replace with LSF singles. Thats what happens when you dont read the architects spec I suppose...
Not sure on the exact requirements but it may be upto the client or I heard something about being used in public buildings e.g shopping centres, schools but then surely you would use it in peoples homes! I also think that sometimes it isn't used where it should be is down to cost because its like 20 quid more than standard PVC cable. I only ever work with LSF now so its seems to be the norm.
Sent from my HTC Desire using Tapatalk
Our council requested to use it up about 2006, so save the house being rewired if the flats or houses got set alight unfortuantly the short sighted council forgot about any containment used, so they ended up reverting back to standard T&E
LSF cable is usually specified under the designers risk assessment not as a regulation....LSF cables have no ability to be fire proof, but are low in toxic fumes, compared to standard pvc.....so designers are trying to prevent a building being filled with toxic fumes.
As I understood it (but could be wrong), LSF is a requirement for tunnels, rail or otherwise, but as others have said it is a designers choice most of the time, or it could be the insurers who require it for public buildings such as shopping centres, colleges, hospitals etc..etc...
It is possibly over used on some projects due to people in charge (insurers etc..) being of primarily office based and non-technical backgrounds.
Again it would be down to the designers and construction companies risk assessment.......for underground rail, the designer may suggest the risk is to high even using lsf, and insist on Piro, or FP100 singles in steel conduit, or steel trunking,.....a large office building over only 2 floors he may suggest LSF as the risk is lower.
Reply to LSF cable in the Australia area at ElectriciansForums.net
