LSZH vs PVC | on ElectriciansForums
Discuss LSZH vs PVC in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
djelectric
Hi everyone. Quick question. In which situations would you use LSZH cables over PVC? Fire alarm systems being obvious but any other reasons/regulations of when/where to use? Thanks
Mind you LSZH doesn't protect the cable it just reduces smoke so maybe not so obvious for fire alarm systems. Is it just something that the client specifies or contractor may recommend as an additional safety precaution in the event of a fire?
Quite a bit ago we had a project in Norway where all the cables had to be LSZH. That doesn't help you out a lot thought, does it.... :)
Reply to LSZH vs PVC in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
If you get a length of conduit, and seal both ends then the IP rating will instantly be IP68!! If you buy an IP66 rated Wiska box it will...
It's galvanised and provided you coat any cut edges with galv spray there should be no signs of undue corrosion any time soon. Galv trunking...
nicebutdim
N
