Lucien Nunes
Broke Internet
Mentor
You've seen some curious stuff in my vintage picture puzzles before but what can you make of this black box? I want to know not only what's inside but also its main electrical specifications; there are two in particular for which I need the actual figures.
There will be a few picture clues to help you along...
Not a transformer. Here's your first clue:
Would it be a pressure/water head level switch sensor/switch? I'm guessing there is a pipe from the big one into the box and then the rusty small one is a vent to allow the water to rise.
The box is maybe a mile away and has no pipes connected to it, only cables.
No sumps or pumps needed here Pete. Although the clues provide information relating to the use of the box, they aren't necessarily part of its functionality.
Those robust metal stays and the strong wooden shelf do give the impression that the box contains a beefy transformer or ballast. In fact I was able to lift it off while standing on a stepladder and pass it down to someone.
I know, it's your tool box with all your best tools inside, I knew all along your just a closet tool tart. Or you have been to Oak Island and found the Templar Treasure.
Looking at picture in #6 one can see:
1. A view looking down to terra firma.
2. Large diameter pipe - so perhaps high volume and low pressure flow. So possibly water in it.
3. A small bore (1") vertical pipe above the larger pipe with a right angle bend into what might be a chamber. Thoughts are: an overflow?, vent?, pressure relief?, or connected to something else to sense level or pressure?
4. Midway up on the left side is what looks a bit like a copper earth electrode, so straight and regular it appears. Or is it a small bore pipe?
The thin thing is the handle of a rake, and the small pipe is a vent. These details aren't really of any importance. The presence and function of the big pipe help to set the scene and give some insight into the electrical situation that will become more apparent in the next pic. In the meantime, I have some work to do.
Is it a signalling device to release water from stored water to low level land when near critical levels are reached , and does it have an ultra violet system to kill the bacteria?
No one else bothered to join in the fun the Lucien, best you coughup and tell us what it is.
Not you an all?
Is it at an old waterworks?
LOL
A flow Meter of some sort?,or a Thermograph
I reckon that is a pipe for expelling in quick time a hazard from the building, the box is monitoring the possible hazard and act as an warning system.... or something along those lines, it may be sampling the toxicity of the air because of a chemical used and in an emergency you open the pipe.
it's a Fart Alert System then?
Look, the box doesn't ontrol the pipe and the pipe doesn't control the box, OK? I'll put another pic up tonight...
Is it just a empty plastic box? I had one just like this on a site where trunking was being installed the lads i worked with basically went around the box with the trunking from one side up over the top and back down like a arch and carryed on and when i went to look at it i pointed out it was empty and they should of just took the box away and gone straight haha
Lucien Nunes
Broke Internet
Mentor
London for the time being
Website
http://www.electrokinetica.org
Lucien's most challenging picture puzzle yet... what does this box do?
Lucien Nunes,
Lucien Nunes,
