Lux level for warehouse forklift | on ElectriciansForums
Discuss Lux level for warehouse forklift in the Lighting Forum area at ElectriciansForums.net
gazdkw82
leicester
What's the recommended levels for a warehouse that has a couple of forklifts operating.
400-500 ok?
It's my first real attempt at designing a lighting setup for an industrial unit so I'm a little unsure.
I'm also having my first go at using relux and have picked a led light fitting from ansell to get a feel for the design
500 is normally for perception with fine working.
It does depend what the warehouse is used for if you want to go less. I’m no designer but have done a warehouse in the past! Enjoy relux, I used dialux for a bit but haven’t touched it in a few years!
It's a good program but quite hard for me to use at the moment. Still trying to work out how to navigate it.
The warehouse is used for storage of metals ans plastics. Mostly used for rollcages and the motorsport industry. There is a large storage racking which holds alot of large lengths of tubes that are moved and sent for deliveries etc using the forklift
Are they manned? Visited lots of automated warehouse hubs,with robot stackers...work in the dark,you know...;)
It's for cost saving. The energy bills are very high and so they want to become more energy efficient.
The lighting was the obvious starting point. All fluorescent, metal halide, halogens etc
I think I'm going to look at daylight dimmer as a bolt on. As you can see from the picture there are skylights. A daylight dimming bolt on should help reduce unneeded light from the system and boost light levels when needed.
Reply to Lux level for warehouse forklift in the Lighting Forum area at ElectriciansForums.net
Problems can arise when you get on too well then they think he won’t mind me doing a bit.
Thanks for the input guys. Lighting track is out of the question. The routing (h section guirders and angle iron) means that swa cable clipped...
